阅读:5326回复:0
启动Nginx时候报错:nginx: [error] open() “/usr/local/nginx/logs/nginx.pid” failed
一、没有指定配置目录输入来使用指定nginx.conf文件的方式重启nginx(首先保证上面第一种情况的pid没有被注释,否则可能前两次能打开,但是以后还是会报错的)
sudo /usr/local/nginx/sbin/nginx -c /usr/local/nginx/conf/nginx.conf /usr/local/nginx/sbin/nginx -s reload //重启 二、nginx.conf的nginx.pid被注释了进入nginx.conf目录编辑 sudo vi /usr/local/nginx/conf/nginx.conf
把注释取消掉,再重新启动Nginx就OK了 sudo nginx -s reload ---------------------------------- https://blog.csdn.net/weixin_45525272/article/details/107980445?ops_request_misc=%257B%2522request%255Fid%2522%253A%2522bb30bc01e053b6f56d9dd8d308197d99%2522%252C%2522scm%2522%253A%252220140713.130102334..%2522%257D&request_id=bb30bc01e053b6f56d9dd8d308197d99&biz_id=0&utm_medium=distribute.pc_search_result.none-task-blog-2~all~top_positive~default-1-107980445-null-null.142^v102^pc_search_result_base7&utm_term=nginx%3A%20%5Berror%5D%20open%28%29%20%2Fusr%2Flocal%2Fnginx%2Flogs%2Fnginx.pid%20failed%20%282%3A%20No%20such%20file%20or%20directory%29&spm=1018.2226.3001.4187 |
