阅读:252回复:0
个人常用npm大全【笔记】
npm启动项目出错 报错:‘Error: error:0308010C:digital envelope routines::unsupported’
首先在命令行修改环境变量:$env:NODE_OPTIONS="--openssl-legacy-provider" 再启动项目:npm run serve 或 yarn start 设置成淘宝镜像(现在不要这么做): npm config set registry https://registry.npm.taobao.org/ //加速npm 其实很多不可用 还原: npm config set registryhttps://registry.npmjs.org --global 下载 prettier 相关依赖 npm install prettier -D //下载 ESLint 相关依赖: pnpm install stylelint stylelint-config-html stylelint-config-recommended-scss stylelint-config-recommended-vue stylelint-config-standard stylelint-config-standard-scss -D pnpm install stylelint-config-recess-order postcss postcss-html vue-eslint-parser -D pnpm install sass sass-loader css-loader style-loader vue-loader postcss-loader -D pnpm install eslint eslint-config-prettier eslint-plugin-prettier eslint-plugin-vue -D pnpm install vue-eslint-parser //polyfill 是 globalthis 包 pnpm install globalthis 然后 import'globalthis/auto' ts: pnpm install @typescript-eslint/eslint-plugin @typescript-eslint/parser -D Git 流程规范配置 pnpm install husky -D pnpm set-script prepare "husky install" pnpm prepare pnpm install lint-staged --D//git commit 信息校验工具,不符合则报错 pnpm install @commitlint/cli @commitlint/config-conventional -D npx husky add .husky/commit-msg 'npx --no-install commitlint --edit "$1"' // 安装 czg,如此一来可以快速使用 czg 命令进行启动。 pnpm install czg -D //标准输出格式的 commitizen 适配器 pnpm install cz-git -D //three npm i --save-dev three npm install three-orbitcontrols three-obj-mtl-loader three-obj-GLTFLoader stats-js --save-dev npm i --save-dev @types/three // 引入three.jsimport * as THREE from 'three'; // 引入扩展库OrbitControls.js import{ OrbitControls} from'three/examples/jsm/controls/OrbitControls'; //gltfimport{ OBJLoader, //MTLLoader , } from'three-obj-mtl-loader'; //obj // 引入扩展库GLTFLoader.js
// 创建3D场景对象Sceneconst scene = new THREE.Scene(); pnpm add ** pnpm install pnpm update pnpm run dev npm update常用命令使用 一、更新 npm-check检查更新 npm install -g npm-check npm-check 2. npm-upgrade更新 npm install -g npm-upgrade npm-upgrade 3. 更新全局包: npm update <name> -g 4. 更新生产环境依赖包: npm update <name> --save 5. 更新开发环境依赖包: npm update <name> --save-dev针对vue2的老代码 babel-core升级为@babel/core ,eslint-loader升级为eslint-webpack-plugin, babel-eslint升级为@babel/eslint-parser https://blog.csdn.net/Uookic/article/details/125680975 安装cnpm(Windows) 更换成淘宝的源npm config set registry https://registry.npm.taobao.org – 配置后可通过下面方式来验证是否成功npm config get registry 先删除原有的所有代理 npm config rm proxynpm config rm https-proxy npm 删除模块 【npm uninstall xxx】删除xxx模块;【npm uninstall -g xxx】删除全局模块xxx; 安装淘宝镜像: npm install -g cnpm --registry=https://registry.npm.taobao.org或 npm i pnpm -g --registry=https://registry.npm.taobao.org (1)npm install -g cnpm --registry=https://registry.npm.taobao.org (2)cnpm -V(3)添加系统变量path的内容 因为cnpm会被安装到D:\Program Files\nodejs\node_global下,而系统变量path并未包含该路径。在系统变量path下添加该路径即可正常使用cnpm。 npm install -g yarnC:\Users\ThinkPad\AppData\Roaming\npm\yarn -> C:\Users\ThinkPad\AppData\Roaming\npm\node_modules\yarn\bin\yarn.js C:\Users\ThinkPad\AppData\Roaming\npm\yarnpkg -> C:\Users\ThinkPad\AppData\Roaming\npm\node_modules\yarn\bin\yarn.js yarn --version添加 jquery : yarn add jqueryyarn add vue yarn add @vue/cli -gyarn add webpack -g 或 yarn add webpack-cli --save-devyarn add vue-loader css-loader vue-template-compiler yarn add vue-routeryarn remove vue-router 举例添加 bootstrap 和 zepto:yarn add bootstrap zepto yarn init 11、发布包:yarn publish 14、运行脚本: yarn dev //启动开发服务器//yarn run //yarn start用来执行在package.json中scripts属性下定义的脚本 vue 使用命令行创建项目: npm install vue vue-loader vue-template-compiler 1:npm install vue-cli -g [安装2.0版本] 不用了 npm install vue-cli-service -g [安装2.0,现在会失败] 不用了 npm uninstall vue-cli -g [卸载2.0版本] npm install @vue/cli -g [安装3.0以上版本] npm install -g @vue/cli-service 或 npm install @vue/cli @vue/cli-service -g 2:npm install webpack -g [全局安装] cnpm install --save-dev webpack [安装到项目目录下] 3. npm install webpack-cli -g [全局安装] cnpm install webpack-cli --save-dev [安装到项目目录下] 4.npm install --save-dev webpack-dev-server [构建本地服务器] npm install axios -s 5:vue init webpack myapp[ 项目名称 ] 6:cd myapp 7. npm i style-loader url-loader file-loader stylus stylus-loader vue-loader css-loader npm i webpack webpack-dev-server cross-env html-webpack-plugin npm i postcss-loader autoprefixer babel-loader babel-core babel-preset-env babel-plugin-transform-vue-jsx npm i file-loader 把 webpack 和它的插件安装到项目: npm install webpack webpack-cli webpack-serve html-webpack-plugin --save-dev npm install node-sass@latest html-loader css-loader style-loader file-loader url-loader --save-dev CSS单独打包插件 npm i extract-text-webpack-plugin 或 npm i mini-css-extract-plugin 8:npm install [安装依赖] 或 npm init [创建package.json文件]标准的npm说明文件,里面蕴含了丰富的信息,包括当前项目的依赖模块,自定义的脚本任务等等 9.输入命令 npm run build进行打包 //必须 npm run build:prod --report ID=screenfull sidebar-container navbar tags-view-container let screenf = document.getElementById('screenfull'); let sidebarcontainer = document.getElementsByClassName('sidebar-container'); let navbar = document.getElementsByClassName('navbar'); let tagsviewcontainer = document.getElementsByClassName('tags-view-container'); screenf.addEventListener('click',function() { sidebarcontainer.style.display = "none"; navbar.style.display = "none"; tagsviewcontainer.style.display = "none"; }) 11、输入cnpm start //必须 运行webpack-dev-server12:启动应用,地址为 localhost:8080 npm run dev npm stop 停止模块基础语法npm stop [-- <args>] npm restart 重新启动模块 基础语法npm restart [-- <args>] 正式环境可以执行以下命令:npm run build npm install vue-routernpm i cross-env //运行环境 cnpm install vue-router<script src="https://unpkg.com/vue/dist/vue.js"></script> <script src="https://unpkg.com/vue-router/dist/vue-router.js"></script>详情见: https://www.runoob.com/vue2/vue-routing.html 浏览器兼容性问题,如有兼容性需求可自行使用 babel-polyfill。// 下载依赖 npm install --save babel-polyfill在入口文件中引入 import 'babel-polyfill'// 或者 require('babel-polyfill') //es6 在 webpack.config.js 中加入 babel-polyfill 到你的入口数组: module.exports = { entry: ['babel-polyfill', './app/js'] } 关于使用html-webpack-plugin 用最新版本的的 html-webpack-plugin你可能还会遇到如下的错误:throw new Error('Cyclic dependency' + nodeRep) 产生这个 bug 的原因是循环引用依赖,如果你没有这个问题可以忽略。目前解决方案可以使用 Alpha 版本 npm i --save-dev html-webpack-plugin@next optimize-css-assets-webpack-plugin 这个插件,它不仅能帮你压缩 css 还能优化你的代码。//配置 optimization: { minimizer: [new OptimizeCSSAssetsPlugin()]; }它不仅压缩了代码、删掉了代码中无用的注释、还去除了冗余的 css、优化了 css 的书写顺序,优化了你的代码 margin: 10px 20px 10px 20px; =>margin:10px 20px;。同时大大减小了你 css 的文件大小。更多优化的细节见文档。 安装 eslint, 用来检查语法报错,当我们书写 js 时,有错误的地方会出现提示。 npm install eslint eslint-config-enough babel-eslint eslint-loader --save-dev 引入Element-UI方式,推荐用插件方式引入 1.Vue create 项目名称2.Vue add element 3. 3.使用npm卸载插件:npm uninstall [-g] [–save-dev]PS:不要直接删除本地插件包 4.使用npm更新插件:npm update [-g] [–save-dev]5.更新全部插件:npm update [–save-dev] 6.查看npm帮助:npm help7.查看当前目录已安装插件:npm list 手机适配:<meta name="viewport" content="width=device-width, initial-scale=1.0, minimum-scale=1.0, maximum-scale=1.0, user-scalable=no"> <meta name="format-detection" content="telephone=no" /><meta name="format-detection" content="email=no" /> <meta name="apple-mobile-web-app-capable" content="yes" /><meta name="apple-mobile-web-app-status-bar-style" content="black" /> <script> var bw = (document.documentElement.clientWidth/6.4)+"px"; var htmlTag = document.getElementsByTagName("html")[0]; htmlTag.style.fontSize=bw; </script> bable 安装: (1):npm install –g babel-cli(2):npm install -g cnpm --registry=https://registry.npm.taobao.org [国内域] (3):npm install --save-dev babel-preset-es2015(4):type nul>.babelrc [创建] 文件中写入{"presets":['es2015']} (5):babel js/es6.js -o js/es5.js 转换(6):babel js/es6.js -o js/es5.js -w [随时更新] gulp 安装:(1): npm install gulp -g [全局安装] (2): npm install gulp --save-dev [安装依赖](3): npm install gulp-sass --save-dev [sass插件] (4): npm install gulp-connect --save-dev [插件搭建本地服务](5): npm install gulp-concat --save-dev [合并插件] (6): npm install gulp-uglify --save-dev [合并js文件进行压缩](7): npm install gulp-rename --save-dev [保留前后压缩两个文件] (8): npm install gulp-sass --save-dev] npm install gulp-clean-css --save-dev [压缩css](9): npm install gulp-imagemin --save-dev [对图片进行压缩] (10):npm install gulp-sourcemaps --save-dev(11):npm install babel-cli --save-dev npm install babel-preset-es2015 --save-dev npm install gulp-babel --save-dev [es6转换es5] 定义: const gulp = require('gulp'); const sass = require('gulp-sass'); const connect = require('gulp-connect'); const concat = require('gulp-concat'); const uglify = require('gulp-uglify'); const rename = require('gulp-rename'); const cleanCss = require('gulp-clean-css'); const imagemin = require('gulp-imagemin'); const babel = require('gulp-babel'); gulp.task("server",function(){ connect.server({ root:"dist", livereload:true }) }); git 分支语句命令: $ ssh-keygen -t rsa -C "youremail@example.com" [创建密钥] $ git config --global user.name "Your Name" $ git config --global user.email "email@example.com" [git 是分布式管理系统 所以需要输入名字和email] $ mkdir learngit [创建项目] $ cd learngit [文件指向] $ pwd [显示当前目录] $ git init [把目录变成可以管理的仓库] 如果使用Windows系统,为了避免遇到各种莫名其妙的问题,请确保目录名(包括父目录)不包含中文 $ git add xx [把文件添加到仓库] $ git commit -m "xx" [把文件提交到仓库] $ git reset --hard HEAD [回退(上一个版本就是HEAD^,上上一个版本就是HEAD^^)] $ git reset --hard commit id [] $ git reflog [记录了你的每一次命令] $ git checkout -- xx [让文件回到你最后提交的状态] $ git reset heard HEAD xx [把暂存区的修改撤销掉] $ git rm xx [删除] $ git status [仓库的当前状态] $ git diff xx [查看改动 (只能在未提交之前使用)] $ git log [显示从最近到最远的提交 (提交历史)] 如果眼花缭乱,可以试试加上--pretty=oneline参数 git branch [查看分支] git branch <name> [创建分支] git checkout <name> [切换分支] git checkout -b <name> [创建+切换分支] git merge <name> [合并某分支到当前分支] git branch -d <name> [删除分支] git log --graph [查看分支合并图] git stash [可以把当前工作现场管理起来] git stash pop [恢复工作现场] npm i webpack-dev-middleware@3.7.2 webpack-dev-server@3.11.0 |
