阅读:417回复:0
个人常用GIT命令大全【笔记】https://e.coding.net/hundda/fuzhouditie/fzdt-web.git git config --global user.name "21707709" git config --global user.email "21707709@qq.com" 克隆密码 qqqq@5***** 创建密钥 生成ssh公钥和私钥: ssh-keygen -t rsa -C "21707709@qq.com" git clone https://e.coding.net/hundda/fuzhouditie/fzdt-web.git clone代码时 注意:username填邮箱 不是填username $ git checkout -b master origin -t: -N:是指密码为空; -f:id_rsa是指保存文件为~/.ssh/id_rsa和~/.ssh/id_rsa.pub -q:指静默模式, 不输出显示 生成的公钥在 C:\Users\Administrator\.ssh\id_rsa.pub 文件。 git账号:21707709@qq.com git密码:qqqq@5***** 创建密钥 生成ssh公钥和私钥: ssh-keygen -t rsa -C "你的云效codeup绑定的邮箱" 生成的公钥在 C:\Users\Administrator\.ssh\id_rsa.pub 文件。 进入复制粘贴你的公钥到云效git的SHH区。 然后就可以 看见项目 和 自由提交代码了。 git克隆账号: gurittooling_QtTp5 克隆密码: qqqq5******* https://code.aliyun.com/ aimap.accessToken = "GXUXQ4UEanLraGhuRasG9pTU4bI0hrbO"; aimap.baseApiUrl = "https://location-dev.newayz.com"; //aimap.baseApiUrl = "http://2.36.27.199:5005"; 原始地址 "devDependencies": { "@vue/cli-plugin-babel": "^3.0.0-rc.9", "@vue/cli-plugin-eslint": "^3.0.0-rc.9", "@vue/cli-plugin-unit-mocha": "^3.0.0-rc.9", "@vue/cli-service": "^3.0.0-rc.9", "@vue/test-utils": "^1.0.0-beta.20", "chai": "^4.1.2", "eslint-plugin-cypress": "^2.0.1", "lint-staged": "^7.2.0", "node-sass": "^4.9.0", "sass-loader": "^7.0.1", "vue-template-compiler": "^2.5.17", "sugonGis": "git+https://code.aliyun.com/zhangax2008/sugongis.git" }, 1. 查看远程分支 $ git branch -a 2. 查看本地分支 我在mxnet根目录下运行以上命令: ~/mxnet $ git branch 回应: * master 3. 切换分支 $ git checkout -b master origin $ git branch 回应: * master * zax $ git checkout master 回应: Branch aoxiang set up to track remote branch aoxiang from origin. Switched to a new branch 'aoxiang' git config --list (1)命令行配置 git config --global user.name "zhangax2008" git config --global user.name "zhangax2008" git config --global user.email "21707709@qq.com" git用户名:zhangax2008 我的GIT密码:qqqq5****** 3dMapGis地址:http://10.0.37.179:8088/3d_map_kunshan/3d_map_gis.git 创建密钥 生成ssh公钥和私钥: ssh-keygen -t rsa -C "21707709@qq.com" -t: -N:是指密码为空; -f:id_rsa是指保存文件为~/.ssh/id_rsa和~/.ssh/id_rsa.pub -q:指静默模式, 不输出显示 生成的公钥在 C:\Users\Administrator\.ssh\id_rsa.pub 文件。 2) 阿里云,必须先点一下 profile设置---公钥,才会显示 ssh keys! 3) 将创建好的公钥,添加到阿里云的 ssh keys 中即可。就可以支持 https 了。 Git常用命令总结 git init 在本地新建一个repo,进入一个项目目录,执行git init,会初始化一个repo,并在当前文件夹下创建一个.git文件夹. git clone 获取一个url对应的远程Git repo, 创建一个local copy. 一般的格式是git clone [url]. clone下来的repo会以url最后一个斜线后面的名称命名,创建一个文件夹,如果想要指定特定的名称,可以git clone [url] newname指定. git status 查询repo的状态. git status -s: -s表示short, -s的输出标记会有两列,第一列是对staging区域而言,第二列是对working目录而言. git log show commit history of a branch. git log --oneline --number: 每条log只显示一行,显示number条. git log --oneline --graph:可以图形化地表示出分支合并历史. git log branchname可以显示特定分支的log. git log --oneline branch1 ^branch2,可以查看在分支1,却不在分支2中的提交.^表示排除这个分支(Window下可能要给^branch2加上引号). git log --decorate会显示出tag信息. git log --author=[author name] 可以指定作者的提交历史. git log --since --before --until --after 根据提交时间筛选log. --no-merges可以将merge的commits排除在外. git log --grep 根据commit信息过滤log: git log --grep=keywords 默认情况下, git log --grep --author是OR的关系,即满足一条即被返回,如果你想让它们是AND的关系,可以加上--all-match的option. git log -S: filter by introduced diff. 比如: git log -SmethodName (注意S和后面的词之间没有等号分隔). git log -p: show patch introduced at each commit. 每一个提交都是一个快照(snapshot),Git会把每次提交的diff计算出来,作为一个patch显示给你看. 另一种方法是git show [SHA]. git log --stat: show diffstat of changes introduced at each commit. 同样是用来看改动的相对信息的,--stat比-p的输出更简单一些. git add 在提交之前,Git有一个暂存区(staging area),可以放入新添加的文件或者加入新的改动. commit时提交的改动是上一次加入到staging area中的改动,而不是我们disk上的改动. git add . 会递归地添加当前工作目录中的所有文件. git diff 不加参数的git diff: show diff of unstaged changes. 此命令比较的是工作目录中当前文件和暂存区域快照之间的差异,也就是修改之后还没有暂存起来的变化内容. 若要看已经暂存起来的文件和上次提交时的快照之间的差异,可以用: git diff --cached 命令. show diff of staged changes. (Git 1.6.1 及更高版本还允许使用 git diff --staged,效果是相同的). git diff HEAD show diff of all staged or unstated changes. 也即比较woking directory和上次提交之间所有的改动. 如果想看自从某个版本之后都改动了什么,可以用: git diff [version tag] 跟log命令一样,diff也可以加上--stat参数来简化输出. git diff [branchA] [branchB]可以用来比较两个分支. 它实际上会返回一个由A到B的patch,不是我们想要的结果. 一般我们想要的结果是两个分支分开以后各自的改动都是什么,是由命令: git diff [branchA]…[branchB]给出的. 实际上它是:git diff $(git merge-base [branchA] [branchB]) [branchB]的结果. git commit 提交已经被add进来的改动. git commit -m “the commit message" git commit -a 会先把所有已经track的文件的改动add进来,然后提交(有点像svn的一次提交,不用先暂存). 对于没有track的文件,还是需要git add一下. git commit --amend 增补提交. 会使用与当前提交节点相同的父节点进行一次新的提交,旧的提交将会被取消. git reset undo changes and commits. 这里的HEAD关键字指的是当前分支最末梢最新的一个提交.也就是版本库中该分支上的最新版本. git reset HEAD: unstage files from index and reset pointer to HEAD 这个命令用来把不小心add进去的文件从staged状态取出来,可以单独针对某一个文件操作: git reset HEAD - - filename, 这个- - 也可以不加. git reset --soft move HEAD to specific commit reference, index and staging are untouched. git reset --hard unstage files AND undo any changes in the working directory since last commit. 使用git reset —hard HEAD进行reset,即上次提交之后,所有staged的改动和工作目录的改动都会消失,还原到上次提交的状态. 这里的HEAD可以被写成任何一次提交的SHA-1. 不带soft和hard参数的git reset,实际上带的是默认参数mixed. 总结: git reset --mixed id,是将git的HEAD变了(也就是提交记录变了),但文件并没有改变,(也就是working tree并没有改变). 取消了commit和add的内容. git reset --soft id. 实际上,是git reset –mixed id 后,又做了一次git add.即取消了commit的内容. git reset --hard id.是将git的HEAD变了,文件也变了. 按改动范围排序如下: soft (commit) < mixed (commit + add) < hard (commit + add + local working) git revert 反转撤销提交.只要把出错的提交(commit)的名字(reference)作为参数传给命令就可以了. git revert HEAD: 撤销最近的一个提交. git revert会创建一个反向的新提交,可以通过参数-n来告诉Git先不要提交. git rm git rm file: 从staging区移除文件,同时也移除出工作目录. git rm --cached: 从staging区移除文件,但留在工作目录中. git rm --cached从功能上等同于git reset HEAD,清除了缓存区,但不动工作目录树. git clean git clean是从工作目录中移除没有track的文件. 通常的参数是git clean -df: -d表示同时移除目录,-f表示force,因为在git的配置文件中, clean.requireForce=true,如果不加-f,clean将会拒绝执行. git mv git rm - - cached orig; mv orig new; git add new git stash 把当前的改动压入一个栈. git stash将会把当前目录和index中的所有改动(但不包括未track的文件)压入一个栈,然后留给你一个clean的工作状态,即处于上一次最新提交处. git stash list会显示这个栈的list. git stash apply:取出stash中的上一个项目(stash@{0}),并且应用于当前的工作目录. 也可以指定别的项目,比如git stash apply stash@{1}. 如果你在应用stash中项目的同时想要删除它,可以用git stash pop 删除stash中的项目: git stash drop: 删除上一个,也可指定参数删除指定的一个项目. git stash clear: 删除所有项目. git branch git branch可以用来列出分支,创建分支和删除分支. git branch -v可以看见每一个分支的最后一次提交. git branch: 列出本地所有分支,当前分支会被星号标示出. git branch (branchname): 创建一个新的分支(当你用这种方式创建分支的时候,分支是基于你的上一次提交建立的). git branch -d (branchname): 删除一个分支. 删除remote的分支: git push (remote-name) :(branch-name): delete a remote branch. 这个是因为完整的命令形式是: git push remote-name local-branch:remote-branch 而这里local-branch的部分为空,就意味着删除了remote-branch git checkout git checkout (branchname) 切换到一个分支. git checkout -b (branchname): 创建并切换到新的分支. 这个命令是将git branch newbranch和git checkout newbranch合在一起的结果. checkout还有另一个作用:替换本地改动: git checkout --<filename> 此命令会使用HEAD中的最新内容替换掉你的工作目录中的文件.已添加到暂存区的改动以及新文件都不会受到影响. 注意:git checkout filename会删除该文件中所有没有暂存和提交的改动,这个操作是不可逆的. git merge 把一个分支merge进当前的分支. git merge [alias]/[branch] 把远程分支merge到当前分支. 如果出现冲突,需要手动修改,可以用git mergetool. 解决冲突的时候可以用到git diff,解决完之后用git add添加,即表示冲突已经被resolved. git tag tag a point in history as import. 会在一个提交上建立永久性的书签,通常是发布一个release版本或者ship了什么东西之后加tag. 比如: git tag v1.0 git tag -a v1.0, -a参数会允许你添加一些信息,即make an annotated tag. 当你运行git tag -a命令的时候,Git会打开一个编辑器让你输入tag信息. 我们可以利用commit SHA来给一个过去的提交打tag: git tag -a v0.9 XXXX push的时候是不包含tag的,如果想包含,可以在push时加上--tags参数. fetch的时候,branch HEAD可以reach的tags是自动被fetch下来的, tags that aren’t reachable from branch heads will be skipped.如果想确保所有的tags都被包含进来,需要加上--tags选项. git remote list, add and delete remote repository aliases. 因为不需要每次都用完整的url,所以Git为每一个remote repo的url都建立一个别名,然后用git remote来管理这个list. git remote: 列出remote aliases. 如果你clone一个project,Git会自动将原来的url添加进来,别名就叫做:origin. git remote -v:可以看见每一个别名对应的实际url. git remote add [alias] [url]: 添加一个新的remote repo. git remote rm [alias]: 删除一个存在的remote alias. git remote rename [old-alias] [new-alias]: 重命名. git remote set-url [alias] [url]:更新url. 可以加上—push和fetch参数,为同一个别名set不同的存取地址. git fetch download new branches and data from a remote repository. 可以git fetch [alias]取某一个远程repo,也可以git fetch --all取到全部repo fetch将会取到所有你本地没有的数据,所有取下来的分支可以被叫做remote branches,它们和本地分支一样(可以看diff,log等,也可以merge到其他分支),但是Git不允许你checkout到它们. git pull fetch from a remote repo and try to merge into the current branch. pull == fetch + merge FETCH_HEAD git pull会首先执行git fetch,然后执行git merge,把取来的分支的head merge到当前分支.这个merge操作会产生一个新的commit. 如果使用--rebase参数,它会执行git rebase来取代原来的git merge. git rebase --rebase不会产生合并的提交,它会将本地的所有提交临时保存为补丁(patch),放在”.git/rebase”目录中,然后将当前分支更新到最新的分支尖端,最后把保存的补丁应用到分支上. rebase的过程中,也许会出现冲突,Git会停止rebase并让你解决冲突,在解决完冲突之后,用git add去更新这些内容,然后无需执行commit,只需要: git rebase --continue就会继续打余下的补丁. git rebase --abort将会终止rebase,当前分支将会回到rebase之前的状态. git push push your new branches and data to a remote repository. git push [alias] [branch] 将会把当前分支merge到alias上的[branch]分支.如果分支已经存在,将会更新,如果不存在,将会添加这个分支. 如果有多个人向同一个remote repo push代码, Git会首先在你试图push的分支上运行git log,检查它的历史中是否能看到server上的branch现在的tip,如果本地历史中不能看到server的tip,说明本地的代码不是最新的,Git会拒绝你的push,让你先fetch,merge,之后再push,这样就保证了所有人的改动都会被考虑进来. git reflog git reflog是对reflog进行管理的命令,reflog是git用来记录引用变化的一种机制,比如记录分支的变化或者是HEAD引用的变化. 当git reflog不指定引用的时候,默认列出HEAD的reflog. HEAD@{0}代表HEAD当前的值,HEAD@{3}代表HEAD在3次变化之前的值. git会将变化记录到HEAD对应的reflog文件中,其路径为.git/logs/HEAD, 分支的reflog文件都放在.git/logs/refs目录下的子目录中. 特殊符号: ^代表父提交,当一个提交有多个父提交时,可以通过在^后面跟上一个数字,表示第几个父提交: ^相当于^1. ~<n>相当于连续的<n>个^. ------------------ 原始邮件 ------------------ 发件人: "苍穹任尔翔" <21707709@qq.com>;发送时间: 2020年10月22日(星期四) 下午5:49 收件人: "苍穹任尔翔"<64222910@qq.com>;"苍穹任尔翔"<21707709@qq.com>; 主题: 我的npm命令大全 运行谷歌 win+rchrome.exe --no-sandbox 安装cnpm(Windows) 更换成淘宝的源npm config set registry https://registry.npm.taobao.org– 配置后可通过下面方式来验证是否成功npm config get registry 先删除原有的所有代理npm config rm proxynpm config rm https-proxy npm 删除模块【npm uninstall xxx】删除xxx模块;【npm uninstall -g xxx】删除全局模块xxx; 安装淘宝镜像:npm install -g cnpm --registry=https://registry.npm.taobao.org (1)npm install -g cnpm --registry=https://registry.npm.taobao.org(2)cnpm -V(3)添加系统变量path的内容因为cnpm会被安装到D:\Program Files\nodejs\node_global下,而系统变量path并未包含该路径。在系统变量path下添加该路径即可正常使用cnpm。 npm install -g yarnC:\Users\ThinkPad\AppData\Roaming\npm\yarn -> C:\Users\ThinkPad\AppData\Roaming\npm\node_modules\yarn\bin\yarn.jsC:\Users\ThinkPad\AppData\Roaming\npm\yarnpkg -> C:\Users\ThinkPad\AppData\Roaming\npm\node_modules\yarn\bin\yarn.js yarn --version添加 jquery :yarn add jqueryyarn add vueyarn add @vue/cli -gyarn add webpack -g或 yarn add webpack-cli --save-devyarn add vue-loader css-loader vue-template-compileryarn add vue-routeryarn remove vue-router举例添加 bootstrap 和 zepto:yarn add bootstrap zeptoyarn init 11、发布包:yarn publish 14、运行脚本:yarn run 用来执行在package.json中scripts属性下定义的脚本 vue 使用命令行创建项目:npm install vue vue-loader vue-template-compiler 1:npm install vue-cli -g [安装2.0版本] npm uninstall vue-cli -g [卸载2.0版本] npm install @vue/cli -g [安装3.0以上版本] 2:npm install webpack -g [全局安装] cnpm install --save-dev webpack [安装到项目目录下] 3. npm install webpack-cli -g [全局安装] cnpm install webpack-cli --save-dev [安装到项目目录下]4.npm install --save-dev webpack-dev-server [构建本地服务器] npm install axios -s 5:vue init webpack myapp[ 项目名称 ] 6:cd myapp 7. npm i style-loader url-loader file-loader stylus stylus-loader vue-loader css-loader npm i webpack webpack-dev-server cross-env html-webpack-plugin npm i postcss-loader autoprefixer babel-loader babel-core babel-preset-env babel-plugin-transform-vue-jsx npm i file-loader 把 webpack 和它的插件安装到项目: npm install webpack webpack-cli webpack-serve html-webpack-plugin html-loader css-loader style-loader file-loader url-loader --save-dev CSS单独打包插件 npm i extract-text-webpack-plugin 或 npm i mini-css-extract-plugin 8:npm install [安装依赖] 或 npm init [创建package.json文件]标准的npm说明文件,里面蕴含了丰富的信息,包括当前项目的依赖模块,自定义的脚本任务等等 9.输入命令npm run build进行打包 //必须npm run build:prod --report ID=screenfullsidebar-container navbar tags-view-container let screenf = document.getElementById('screenfull'); let sidebarcontainer = document.getElementsByClassName('sidebar-container'); let navbar = document.getElementsByClassName('navbar'); let tagsviewcontainer = document.getElementsByClassName('tags-view-container'); screenf.addEventListener('click',function() { sidebarcontainer.style.display = "none"; navbar.style.display = "none"; tagsviewcontainer.style.display = "none"; }) 11、输入cnpm start //必须运行webpack-dev-server12:启动应用,地址为 localhost:8080 npm run dev npm stop 停止模块基础语法npm stop [-- <args>]npm restart 重新启动模块 基础语法npm restart [-- <args>] 正式环境可以执行以下命令:npm run build npm install vue-routernpm i cross-env //运行环境 cnpm install vue-router<script src="https://unpkg.com/vue/dist/vue.js"></script><script src="https://unpkg.com/vue-router/dist/vue-router.js"></script>详情见:https://www.runoob.com/vue2/vue-routing.html 浏览器兼容性问题,如有兼容性需求可自行使用 babel-polyfill。// 下载依赖npm install --save babel-polyfill在入口文件中引入import 'babel-polyfill'// 或者require('babel-polyfill') //es6 在 webpack.config.js 中加入 babel-polyfill 到你的入口数组: module.exports = { entry: ['babel-polyfill', './app/js']} 关于使用html-webpack-plugin用最新版本的的 html-webpack-plugin你可能还会遇到如下的错误:throw new Error('Cyclic dependency' + nodeRep)产生这个 bug 的原因是循环引用依赖,如果你没有这个问题可以忽略。目前解决方案可以使用 Alpha 版本npm i --save-dev html-webpack-plugin@next optimize-css-assets-webpack-plugin 这个插件,它不仅能帮你压缩 css 还能优化你的代码。//配置optimization: { minimizer: [new OptimizeCSSAssetsPlugin()];}它不仅压缩了代码、删掉了代码中无用的注释、还去除了冗余的 css、优化了 css 的书写顺序,优化了你的代码 margin: 10px 20px 10px 20px; =>margin:10px 20px;。同时大大减小了你 css 的文件大小。更多优化的细节见文档。 安装 eslint, 用来检查语法报错,当我们书写 js 时,有错误的地方会出现提示。npm install eslint eslint-config-enough babel-eslint eslint-loader --save-dev 引入Element-UI方式,推荐用插件方式引入1.Vue create 项目名称2.Vue add element3. 3.使用npm卸载插件:npm uninstall [-g] [–save-dev]PS:不要直接删除本地插件包4.使用npm更新插件:npm update [-g] [–save-dev]5.更新全部插件:npm update [–save-dev]6.查看npm帮助:npm help7.查看当前目录已安装插件:npm list 手机适配:<meta name="viewport" content="width=device-width, initial-scale=1.0, minimum-scale=1.0, maximum-scale=1.0, user-scalable=no"><meta name="format-detection" content="telephone=no" /><meta name="format-detection" content="email=no" /><meta name="apple-mobile-web-app-capable" content="yes" /><meta name="apple-mobile-web-app-status-bar-style" content="black" /><script> var bw = (document.documentElement.clientWidth/6.4)+"px"; var htmlTag = document.getElementsByTagName("html")[0]; htmlTag.style.fontSize=bw;</script> bable 安装:(1):npm install –g babel-cli(2):npm install -g cnpm --registry=https://registry.npm.taobao.org [国内域](3):npm install --save-dev babel-preset-es2015(4):type nul>.babelrc [创建] 文件中写入{"presets":['es2015']}(5):babel js/es6.js -o js/es5.js 转换(6):babel js/es6.js -o js/es5.js -w [随时更新] gulp 安装:(1): npm install gulp -g [全局安装](2): npm install gulp --save-dev [安装依赖](3): npm install gulp-sass --save-dev [sass插件](4): npm install gulp-connect --save-dev [插件搭建本地服务](5): npm install gulp-concat --save-dev [合并插件](6): npm install gulp-uglify --save-dev [合并js文件进行压缩](7): npm install gulp-rename --save-dev [保留前后压缩两个文件](8): npm install gulp-sass --save-dev] npm install gulp-clean-css --save-dev [压缩css](9): npm install gulp-imagemin --save-dev [对图片进行压缩](10):npm install gulp-sourcemaps --save-dev(11):npm install babel-cli --save-dev npm install babel-preset-es2015 --save-dev npm install gulp-babel --save-dev [es6转换es5] 定义: const gulp = require('gulp'); const sass = require('gulp-sass'); const connect = require('gulp-connect'); const concat = require('gulp-concat'); const uglify = require('gulp-uglify'); const rename = require('gulp-rename'); const cleanCss = require('gulp-clean-css'); const imagemin = require('gulp-imagemin'); const babel = require('gulp-babel'); gulp.task("server",function(){ connect.server({ root:"dist", livereload:true }) }); git 分支语句命令: $ ssh-keygen -t rsa -C "youremail@example.com" [创建密钥] $ git config --global user.name "Your Name" $ git config --global user.email "email@example.com" [git 是分布式管理系统 所以需要输入名字和email] $ mkdir learngit [创建项目] $ cd learngit [文件指向] $ pwd [显示当前目录] $ git init [把目录变成可以管理的仓库] 如果使用Windows系统,为了避免遇到各种莫名其妙的问题,请确保目录名(包括父目录)不包含中文 $ git add xx [把文件添加到仓库] $ git commit -m "xx" [把文件提交到仓库] $ git reset --hard HEAD [回退(上一个版本就是HEAD^,上上一个版本就是HEAD^^)] $ git reset --hard commit id [] $ git reflog [记录了你的每一次命令] $ git checkout -- xx [让文件回到你最后提交的状态] $ git reset heard HEAD xx [把暂存区的修改撤销掉] $ git rm xx [删除] $ git status [仓库的当前状态] $ git diff xx [查看改动 (只能在未提交之前使用)] $ git log [显示从最近到最远的提交 (提交历史)] 如果眼花缭乱,可以试试加上--pretty=oneline参数 git branch [查看分支] git branch <name> [创建分支] git checkout <name> [切换分支] git checkout -b <name> [创建+切换分支] git merge <name> [合并某分支到当前分支] git branch -d <name> [删除分支] git log --graph [查看分支合并图] git stash [可以把当前工作现场管理起来] git stash pop [恢复工作现场] npm i webpack-dev-middleware@3.7.2 webpack-dev-server@3.11.0 |
