阅读:241回复:0
Use // eslint-disable-next-line to ignore the next line.vue关闭eslint语法检查 启动项目时报错 You may use special comments to disable some warnings. Use // eslint-disable-next-line to ignore the next line. Use /* eslint-disable */ to ignore all warnings in a file. 解决方法: 这样就解决了 代码如下: lintOnSave:false //关闭eslint检查 修改完vue.config.js中的配置一定要重新启动服务 ———————————————— 版权声明 原文链接:https://blog.csdn.net/m0_65382120/article/details/124155732 |
