  • 发帖数1416
阅读:176回复:0
Linux系统安装dpkg命令详细过程(sudo: dpkg: command not found的解决)
更多 发布于:2025-05-10 16:50
1、下载dpkg命令的安装包epel-release-6-8.noarch.rpm
wget -c http://archives.fedoraproject.org/pub/archive/epel/6/x86_64/epel-release-6-8.noarch.rpm
2、解压安装包
rpm -ivh epel-release-6-8.noarch.rpm
3、输入yum install dpkg后出现报错(解决方法为一下几步):
Error: Package: dpkg-1.16.18-3.el6.x86_64 (epel)
           Requires: liblzma.so.0()(64bit)
4、下载liblzma.so的安装包xz-compat-libs-5.2.2-1.el7.x86_64.rpm
wget -c http://mirror.centos.org/centos/7/os/x86_64/Packages/xz-compat-libs-5.2.2-1.el7.x86_64.rpm
5、解压安装包xz-compat-libs-5.2.2-1.el7.x86_64.rpm
rpm -ivh xz-compat-libs-5.2.2-1.el7.x86_64.rpm
6、重新输入yum install dpkg安装dpkg
https://blog.csdn.net/hjxloveqsx/article/details/127388552?ops_request_misc=%257B%2522request%255Fid%2522%253A%252282d2715c21c69a98e45f41a6eec62d43%2522%252C%2522scm%2522%253A%252220140713.130102334..%2522%257D&request_id=82d2715c21c69a98e45f41a6eec62d43&biz_id=0&utm_medium=distribute.pc_search_result.none-task-blog-2~all~sobaiduend~default-2-127388552-null-null.142^v102^pc_search_result_base7&utm_term=dpkg%3A%20command%20not%20found&spm=1018.2226.3001.4187
