  • 发帖数1377
阅读:3600回复:1
babel升级,踩坑!Error: Cannot find module '@babel/core'
更多 发布于:2021-07-02 14:17
babel-loader@8 requires Babel 7.x (the package '@babel/core'). If you'd like to use Babel 6.x ('babel-core'), you should install 'babel-loader@7'.
    at Function.Module._resolveFilename (module.js:547:15)
    at Function.Module._load (module.js:474:25)
    at Module.require (module.js:596:17)
    at require (internal/module.js:11:18)
在这里插入图片描述
没找到@babel/core,需要把babel-core卸载掉,从新安装@babel/core
npm un babel-core
npm i -D @babel/core
  • 发帖数1377
发布于:2021-07-02 14:18
