阅读:2793回复:1
Error: Rule can only have one resource source (provided resource and test + include + exclude)问题:Error: Rule can only have one resource source (provided resource and test + include + exclude) Error: Rule can only have one resource source (provided resource and test + include + exclude) in "exclude": [ null ], "use": [ { "loader": "/Users/juanpablo/front-treatments/node_modules/cache-loader/dist/cjs.js", "options": { "cacheDirectory": "/Users/juanpablo/front-treatments/node_modules/.cache/babel-loader", "cacheIdentifier": "81fef5a6" }, "ident": "clonedRuleSet-38[0].rules[0].use[0]" }, { "loader": "/Users/juanpablo/front-treatments/node_modules/babel-loader/lib/index.js", "options": "undefined", "ident": "undefined" } ] } ```` A complete log of this run can be found in: 0 info it worked if it ends with ok 1 verbose cli [ 1 verbose cli '/Users/juanpablo/.nvm/versions/node/v12.19.0/bin/node', 1 verbose cli '/Users/juanpablo/.nvm/versions/node/v12.19.0/bin/npm', 1 verbose cli 'run', 1 verbose cli 'serve' 1 verbose cli ] 2 info using npm@6.14.8 3 info using node@v12.19.0 4 verbose run-script [ 'preserve', 'serve', 'postserve' ] 5 info lifecycle vue-dashboard@0.1.0~preserve: vue-dashboard@0.1.0 6 info lifecycle vue-dashboard@0.1.0~serve: vue-dashboard@0.1.0 7 verbose lifecycle vue-dashboard@0.1.0~serve: unsafe-perm in lifecycle true 8 verbose lifecycle vue-dashboard@0.1.0~serve: PATH: /Users/juanpablo/.nvm/versions/node/v12.19.0/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/Users/juanpablo/front-treatments/node_modules/.bin:/Users/juanpablo/.nvm/versions/node/v12.19.0/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Users/juanpablo/.rvm/bin 9 verbose lifecycle vue-dashboard@0.1.0~serve: CWD: /Users/juanpablo/front-treatments 10 silly lifecycle vue-dashboard@0.1.0~serve: Args: [ '-c', 'vue-cli-service serve' ] 11 silly lifecycle vue-dashboard@0.1.0~serve: Returned: code: 1 signal: null 12 info lifecycle vue-dashboard@0.1.0~serve: Failed to exec serve script 13 verbose stack Error: vue-dashboard@0.1.0 serve: `vue-cli-service serve` 13 verbose stack Exit status 1 13 verbose stack at EventEmitter.<anonymous> (/Users/juanpablo/.nvm/versions/node/v12.19.0/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16) 13 verbose stack at EventEmitter.emit (events.js:314:20) 13 verbose stack at ChildProcess.<anonymous> (/Users/juanpablo/.nvm/versions/node/v12.19.0/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14) 13 verbose stack at ChildProcess.emit (events.js:314:20) 13 verbose stack at maybeClose (internal/child_process.js:1021:16) 13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5) 14 verbose pkgid vue-dashboard@0.1.0 15 verbose cwd /Users/juanpablo/front-treatments 16 verbose Darwin 19.6.0 17 verbose argv "/Users/juanpablo/.nvm/versions/node/v12.19.0/bin/node" "/Users/juanpablo/.nvm/versions/node/v12.19.0/bin/npm" "run" "serve" 18 verbose node v12.19.0 19 verbose npm v6.14.8 20 error code ELIFECYCLE 21 error errno 1 22 error vue-dashboard@0.1.0 serve: `vue-cli-service serve` 22 error Exit status 1 23 error Failed at the vue-dashboard@0.1.0 serve script. 23 error This is probably not a problem with npm. There is likely additional logging output above. 24 verbose exit [ 1, true ] 原因分析: package.json中webpack版本冲突问题。 解决方案: 删除webpack,重新装以前的版本。 npm uninstall webpack npm install webpack@^4.0.0 --save-dev |
发布于:2022-07-14 11:09
