阅读:549回复:0
npm ERR! request to https://registry.npm.taobao.org/npm failed, reason: certificate has expirednpm ERR! request to https://registry.npm.taobao.org/npm failed, reason: certificate has expired npm ERR! code CERT_HAS_EXPIRED npm ERR! errno CERT_HAS_EXPIRED npm ERR! request to https://registry.npm.taobao.org/npm failed, reason: certificate has expirednpm ERR! A complete log of this run can be found in: npm ERR! C:\Users\rw\AppData\Local\npm-cache\_logs\2024-01-23T12_58_39_805Z-debug-0.log 解决方法: npm config set registry http://registry.npmjs.org/ 若还不行,就: npm cache clean --forcenpm config set strict-ssl false npm install |
