阅读:4785回复:1
ECshop安装问题一解决:Strict Standards: Non-static method cls_image::gd_version() should not be called statiECshop安装问题一解决:Strict Standards: Non-static method cls_image::gd_version() should not be called statically in …… |
发布于:2020-02-17 23:36
在安装Ecshop 2.7.3版本的时候,遇到两个问题:
1.Strict Standards: Non-static method cls_image::gd_version() should not be called statically in D:\X\www\ecshop\install\includes\lib_installer.php on line 31 解决:找到include/cls_image.php中的678行,发现gd_version()方法未声明静态static,所以会出错。这时候只要: 将function gd_version()改成static function gd_version()即可。 点赞 ———————————————— https://blog.csdn.net/fjnjxr/article/details/52411904 原文链接:https://blog.csdn.net/fjnjxr/article/details/52411904 |
