阅读:7981回复:1
ECSHOP报错: Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace……
ECSHOP报错: Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead……
发布于:2020-02-17 23:43
解决办法:
1. Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in \includes\cls_template.php on line 300 原有内容: return preg_replace("/{([^\}\{]*)}/e", "\$this->select('\\1');", $source); 修改后内容: return preg_replace_callback("/{([^\}\{]*)}/", function($r) { return $this->select($r[1]); }, $source); 2. Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in \includes\cls_template.php on line 491 原有内容: $out = "<?php " . '$k = ' . preg_replace("/(\'\\$[^,] )/e" , "stripslashes(trim('\\1','\''));", var_export($t, true)) . ";"; 修改后内容: $out = "<?php " . '$k = ' . preg_replace_callback("/(\'\\$[^,] )/" , function($match){return stripslashes(trim($match[1],'\''));}, var_export($t, true)) . ";" 3. Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in \includes\cls_template.php on line 550 原有内容: $val = preg_replace("/\[([^\[\]]*)\]/eis", "'.'.str_replace('$','\$','\\1')", $val); 修改后内容: $val = preg_replace_callback('/\[([^\[\]]*)\]/is',function ($matches) {return '.'.str_replace('$','\$',$matches[1]);},$val); 4. Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in \includes\cls_template.php on line 1074 原有内容: $source = preg_replace($pattern, $replacement, $source); 修改后内容: $source = preg_replace_callback($pattern, function ($matches) { return '{include file='.strtolower($matches[1]). '}';},$source); 5. Strict Standards: Only variables should be passed by reference in ...\upload\includes\lib_main.php on line 1329 原有内容: $ext = end(explode('.', $tmp)); 修改后内容: $extsub = explode('.', $tmp); $tmp = end($extsub); $tmp = basename($tmp,".$ext"); 最后,将错误修改后,上传到服务器.然后进入后台,清空缓存,刷新页面即可。 |
