  • 发帖数1377
阅读:4025回复:1
Vue2.0 报错:Avoid mutating a prop directly since the value will be overwritten whenever
更多 发布于:2020-09-18 09:57
报错原因:
所有的 prop 都使得其父子 prop 之间形成了一个单向下行绑定:父级 prop 的更新会向下流动到子组件中,但是反过来则不行。(父组件更新,子组件中的prop值也会更新,但子组件不能修改由父组件传递过来的值)
解决办法:
   定义一个本地的 data 属性并将这个 prop 用作其初始值,同步对组件的修改,再通知父组件更新
  • 发帖数1377
发布于:2020-09-18 10:52
解决办法:
相关代码:
  1. <div class="rating-type">
  2. <span @click="select(2,$event)" class="block positive" :class="{'active': selectedtype === 2}">pw_desc.all
  3. <span class="count">47</span>
  4. </span>
  5. <span @click="select(0,$event)" class="block positive" :class="{'active': selectedtype === 0}">pw_desc.positive
  6. <span class="count">50</span>
  7. </span>
  8. <span @click="select(1,$event)" class="block negative" :class="{'active': selectedtype === 1}">pw_desc.negative
  9. <span class="count">47</span>
  10. </span>
  11. </div>
子组件:
  1. data() {
  2. return {
  3. typeSelected: this.selectType,
  4. contOnly: this.onlyContent
  5. };
  6. },
  7. methods: {
  8. select(type, event) {
  9. if (!event._constructed) {
  10. return;
  11. }
  12. this.typeSelected = type;
  13. this.$emit('change', type);
  14. },
  15. toggleContent(event) {
  16. if (!event._constructed) {
  17. return;
  18. }
  19. this.contOnly = !this.contOnly;
  20. this.$emit('toggle', this.contOnly);
  21. }
  22. }
父组件:
  1. <ratingselect :select-type="selectType" :only-content="onlyContent"
  2. :desc="desc" :ratings="food.ratings"
  3. @change="change" @toggle="toggle"></ratingselect>
  1. methods: {
  2. //  子组件更新的值
  3. change(type) {
  4. this.selectType = type;
  5. },
  6. toggle(val) {
  7. this.onlyContent = val;
  8. },
  9. //  子组件更新的值==结束
效果图:
官方文档链接:https://cn.vuejs.org/v2/guide/components-props.html
