阅读:3500回复:1
vue实现九宫格抽奖html <div class="gameBox"> <div class="bg1"></div> <div class="bg2" v-show="lampShow"></div> <div class="start" @click="move"> <p>(pw_number_of_draws次)</p> </div> <ul> <li v-for="(item,i) in list" :key="i" :class="['item' + (i+1), {'active': index == i}]"> <div class="img1"> <img :src="item.image" alt=""> </div> <p>+pw_item.numberpw_item.prize_name</p> </li> </ul> </div> css /* 整体布局采用定位实现 gameBox:父盒子,最外层背景图 bg1:灰色灯 bg2:点击开始按钮后,白色灯出现,同时要每个500s同bg1做切换隐藏显示 start:按钮样式 item1-8:通过定位方式将dom元素顺时针排列 active:点击开始开妞后,从1位置开始高亮,类似跑马灯 */ .gameBox { display: flex; align-items: center; justify-content: center; width: 326px; height: 326px; margin: 150px auto 0; border-radius: 8px; background: url(../../common/images/home/game1.png)no-repeat left top; background-size: 326px 326px; position: relative; .bg1 { position: absolute; left: 4.5px; top: 4px; width: 317px; height: 317px; background: url(../../common/images/home/game3.png)no-repeat center; background-size: 317px 317px; } .bg2 { position: absolute; left: 4.5px; top: 4px; width: 317px; height: 317px; background: url(../../common/images/home/game2.png)no-repeat center; background-size: 317px 317px; } .start { position: relative; padding-top: 70px; width: 86px; height: 86px; background: url(../../common/images/home/game4.png)no-repeat center; background-size: 86px 86px; p { text-align: center; font-size: 12px; font-weight: 400; color: rgba(255, 255, 255, 1); } } ul { li { position: absolute; width: 86px; height: 86px; background: rgba(255, 255, 255, 1); border: 2px solid rgba(227, 161, 0, 1); border-radius: 8px; .img1 { margin: 15px auto 3px; width: 35px; height: 35px; img { width: 100%; height: auto; } } p { text-align: center; font-size: 13px; font-weight: 500; color: rgba(153, 153, 153, 1); } } .item1 {left: 25px;top: 25px;} .item2 {left: 120px;top: 25px;} .item3 {left: 215px;top: 25px;} .item4 {left: 215px;top: 120px;} .item5 {left: 215px;top: 215px;} .item6 {left: 120px;top: 215px;} .item7 {left: 25px;top: 215px;} .item8 {left: 25px;top: 120px;} .active {background: #FFF2B1;} } } js data() { return { list: [],//奖品列表 index: 0, // 当前转动到哪个位置,第一次起点位置0,对应页面item1位置 count: 8, // 总共有多少个位置 times: 0, // 转动跑格子次数, cycle: 60, // 转动基本次数:即至少需要转动多少次再进入抽奖环节 speed: 200, // 初始转动速度 lampShow:false,//开始抽奖,灯光闪烁 timer: 0, // 转动定时器 lamp:0, // 灯光定时器 prize: 0, // 中奖位置,接口返回 number_of_draws:0,//限制每天抽奖次数,接口返回 prize_data: {//中奖信息 id:Number,//奖品ID name:'',//奖品名称 number:Number,//奖品数量 image:'',//奖品图片 type:Number,// 奖品类型 }, } }, mounted() { //获取奖品列表 this.axios.post('/api/luckdraw/prizeList').then(res=>{ if(res.status == 1){ this.list = res.data.list; // 奖品列表数据 this.number_of_draws = res.data.number_of_draws; // 该用户剩余抽奖次数 } }) }, methods: { //点击开始抽奖 move() { if( this.number_of_draws == 0){ this.$toast('今日抽奖次数已用完,明天再来吧'); }else if(this.times != 0){ this.$toast('正在抽奖中,请勿重复点击') } else{ this.axios.post(baseURL+'/api/luckdraw/doDraw').then(res=>{ if(res.status == 1){ this.number_of_draws--;//抽奖开始,次数-1 this.speed = 200;//每次抽奖速度初始化为200 this.prize_data = res.data.yes;//已经拿到中奖信息,页面展示,等抽奖结束后,将弹窗弹出 this.prize = res.data.yes.id -1;//中奖位置赋值,跑马灯最终停留位置,这里实际位置需要-1 this.startRoll();//执行抽奖 this.lamp = setInterval(()=>{//灯光闪烁开启 this.lampShow = !this.lampShow; },500) } }) } }, // 开始转动 startRoll() { this.times += 1; // 转动次数 this.oneRoll(); // 转动过程调用的每一次转动方法,这里是第一次调用初始化 this.usePrize(); }, // 每一次转动 oneRoll() { let index = this.index; // 当前转动到哪个位置 const count = 8; // 总共有多少个位置 index += 1; if (index > count - 1) { index = 0; } this.index = index; }, usePrize() { // 如果当前转动次数达到要求 && 目前转到的位置是中奖位置 if (this.times > this.cycle +10 && this.prize === this.index) { clearTimeout(this.timer); // 清除转动定时器 clearTimeout(this.lamp); // 清除灯光定时器 this.lampShow = false; // 白色灯隐藏 this.times = 0; // 转动跑格子次数初始化为0,可以开始下次抽奖 if(this.prize_data.type == 0){ congsole.log('未中奖,谢谢参与');//未中奖提示弹出, }else{ congsole.log('中奖啦');//中奖弹出提示 } } else { if(this.times < this.cycle -20){ this.speed -= 4; // 加快转动速度 }else{ this.speed += 10; // 抽奖即将结束,放慢转动速度 } this.timer = setTimeout(this.startRoll, this.speed);//开始转动 } }, }, list数组 |
发布于:2021-06-21 08:52
